• What’s the desirable way to capture flash audio?
    Moira
    Views : 5308 Replies : 3 Likes : 0 #1
    Hey guys,I’ve got a bit of dilemma. A couple of days ago, I just stumbled across a funny video that shared by my Facebook friend. According to the URL it provides, I can directly download this flash video from website using a video downloader but not audio I want. I googled how to do this but I failed. Does anyone have a way to capture flash audio files like this?
    Chole
    It’s true that sometimes you may find that it’s kind of difficult to find the music or sound tracks in flash-based games or movies on the Internet. In order to spare you the trouble of struggling for a long time attempting to save flash audio, here I will introduce you a pretty convenient way to capture it.
    MP3 Grabber is specially designed for users who want to transfer video to audio files. To capture flash audio stream, you just need to copy the URL of the video you like and paste it on the search bar, then click Convert. Within a few seconds, a java window will pop up, just hit the Enable button to launch this tool. In this way, this flash audio will be automatically grabbed to download.
    Moira
    Still having a problem. What if I just wanna keep part of the flash audio?
    • avatar
      • Chole : If so, you'd better use a flash audio recorder which enables you to record the audio of any part of the video. Streaming Audio Recorder can be a desirable option for you. As an audio recording program, just as the online audio recorder I mentioned above, it has the capability to record any audio and it is not restricted to specific website or format of audio you are listening. Except that, it combines audio editor, audio converter, and CD burner, together with many other functions.
        With this Streaming Audio Recorder, there are two ways available for you to capture flash audio, the first way is to download the whole flash audio track and select part of flash audio as you want. The second way is to directly record it.
        More detailed steps concerning the first step are as follows.
        Select Video to Mp3 in the drop-down list of Tools and paste the URL of the flash video in the URL bar. Next, click Add to Download, in this way this video can be transferred into audio files. Then, choose Audio Editor tool to edit the flash audio you have just transferred by selecting any section of the flash audio.
        In case that you may think it's a bit troublesome to save flash audio in the above way, I will show you a quicker way by recording it. You can refer to the following steps to record flash audio:
        Step one: Download and run the Streaming Audio Recorder.
        Step two: Change the settings as you wish. The overall settings consist of record settings, general settings and download settings. You can not only select your preferred output folder and format, but also to change the audio source and other advanced settings.
        Step three: Play the flash video and hit the On button to start recording. You'd better simply click on the plus to turn Automatically skip silent passages in the process of recording into a check-mark in the Record settings. Then, your recording won't contain several silent passages due to the video lag causing by the unstable network.
        Step four: Click Off to finish your recording.
        Now your flash audio has been recorded, you can keep it on your computer or transfer it to your portable devices for preservation.
      • 2013-09-29 19:25 Reply
reply to: What’s the desirable way to capture flash audio?
