• virtual sound card
    jknapp
    virtual sound card
    Views : 3713 Replies : 3 Likes : 0 #1
    Hi, trying to down load the trial version before buying on macbook and it says the virtual sound card can’t be detected. when i try and install, i get install failed, please reboot…but I try that and it doesnt work.
    virtual sound card
    Jessica
    Hi, you can refer to the info in this post. Just follow the guides, then you’ll install the visual sound card successfully.
    failed-to-install-apowersoft-virtual-sound-card.html
    virtual sound card
    agostinhoncn
    Hi, trying to install Screen Record on my macbook and it says the virtual sound card can’t be detected. when i try and install, i get install failed, please reboot…but I try that and it doesnt work.
    • avatar
      • Ada Reed :
        Dear User, please click "No" when the virtual sound card installation window first pops up, then relaunch the program and choose "Yes" when that window pops up again. It should be fine by then. Thnak you for your support and understanding!
      • 3 years, 3 months ago Reply
reply to: virtual sound card
