• Two problems: No longer downloads & on record screen no sound
    strngqrk
    Views : 380 Replies : 1 Likes : 0 #1
    For some reason my Video Download program is no longer downloading. It starts like usual bit after 6 to 12 seconds it stops & a exclamation point in a red circle shows up at the extreme left hand edge. What does that mean? Any solutions?
    For awhile now if I download the screen, the audio portion fails & it records in silence. Why is this? What can be done?
    I’ve looked for updates but there are none.
    Fiona
    Hello, which website do you download the video from? Did you use recording but didn’t help? Please send us a link to the website to test it
reply to: Two problems: No longer downloads & on record screen no sound
