• Sound problems
    Kacchan
    Sound problems
    Views : 691 Replies : 6 Likes : 1 #1
    my screen is always louder than my voice what can i do thats literaly all you guys have to do i don’t know how to make my voice sound louder… can anyone help?
    Sound problems
    Apowersoft
    Threads : 33
    Hi, do you mean in your recording, the system sound is louder than your microphone sound? If so, which program did you use?
    Sound problems
    jwangmba
    Hi- I’m evaluating your screen capture function and notice sound cuts out at 2:45 or so out of the 3:00 min trial. If I get the paid version, will this fix the problem? I don;t want to get the software and find out there is still an issue (as there are other options out there). I’m on 12″ MacBook running Catalina 10.15.6
    • avatar
      • Alice Wang :
        Dear  user, please kindly tell us which program you are currently using, is it mac apowerrec or mac screen recorder? Please download the latest version of mac apowerrec and log into the registered account, then try out to see whether the issue is still there. Thank you!
      • 2020-10-14 22:38 Reply
    Sound problems
    ditz.ortaleza
    Hi, every time I record from screen there is always a distorted sound after recording it.
    kindly let me know how to solve this issue please. many thanks
    Sound problems
    ditz.ortaleza
    #5
    Hi, every time I start recording from the screen there is always a distorted sound in the process. please help me how to fix the issue. many thanks.
    Sound problems
    jarreola81
    #6
    Hello, every time I want to record the screen, it asks me to download the software but I have already downloaded it … and the sound or the microphone is never configured when the program starts and I don’t know how to do it.
    • avatar
      • Alice Wang :
        Dear user, could you please kindly tell us which recording software you are currently using and which system you are using it for at the moment, and we will then move forward to solve the problem. Thank you!
      • 2020-10-18 22:20 Reply
    Sound problems
    Hans Nicolas
    #7
    Video Download Capture
    when I record screen recording from a powerpoint presentation I have problems with the sound. the recording becomes gritty. I also have a video I play in the presentation. the sound in the video begins before I start inside the recording finished. how do i fix it ??
    I start the video 10 seconds after changing the powerpoint slide, but in the recording, the sound starts before I change the slide. was not like this for 2 weeks ago.
    and get this error some times
reply to: Sound problems
