Hi – Just starting to use the Audio Recorder program. Love it so far! I want to make sure I’m making the highest quality recordings I can. In the settings I have selected high quality and a lossless codec format. I’m also wondering if the quality of the sound card in my PC will play a factor in the recordings? i.e. If I use the same settings to record audio on 2 different PCs… one with a cheap sound card and one with a high quality sound card, with the recordings be any different? Thanks!!
