• screen recorder pro not recording video sound or picture
    Anonymous
    Views : 1633 Replies : 5 Likes : 0 #1
    I cannot seem to get a recording of the sound or video when recording the screen while watching an amazon video. What is the problem?
    Hi, sorry for the problem. Please write down the link address of Amazon video you are recording. We will test and help you analyze it soon.
    flashkes
    i don’t have a Amazon video.
    what should i do?
    flashkes
    the system in my computer is MacOS Catalina, maybe this is the problem?
    i download ApoweREC in another computer and the software works very well.
    verityleadershipdevelopment
    #5
    I’m also having the same issue. I press the record button, it counts down, then doesn’t seem to do anything after.
    I am running Windows 10 Pro v.2004 OS Build 19041.746. It used to work (about 6 months ago)
    • avatar
      • Alice Wang :
        Dear user,
        So sorry for this issue, in this case, please try running the program as the administrator. If that's not working, please enter the settings and change the default saving folder to a new one except for disk C. And it should be fine by then.
        Thank you very much for your support and understanding!
      • 10 months ago Reply
reply to: screen recorder pro not recording video sound or picture
