• RECORDING FROM SPOTIFY VOLUME TOO LOW
    arojas
    Views : 1649 Replies : 1 Likes : 0 #1
    HI, I TRY TO REDORD FROM SPOTIFY AND THE RECORDING VOLUME IS TOO LOW COMPARED TO MY REGULAR RECORDINGS.  I HAVE TRIED WITH THE DIFFERENT INPUT DEVICES: MICROPHONE, APOWERSOFT AUDIO DEVIECE, LAEWO AUDIO DEVICE AND AGGREGATE DEVICE AND FOR THE MICROPHONE I PUT THE INPUT LEVEL TO THE MAX AND STILL THE RECORDING IS TOO LOW.  WICH DEVICE SHOULD I USE AND WHAT IS THE SOLUTION TO INCREASE MY RECORDING LEVEL SO THAT IT IS THE SAME AS MY REGULAR FILES.  I HAVE A MAC BOOK PRO
    Hi, thanks for using our software. Please make sure your computer system sound volume, volume on recorder, recording volume is above 60%.
reply to: RECORDING FROM SPOTIFY VOLUME TOO LOW
