• Record parts of a You Tube video
    Gubert
    Views : 1936 Replies : 2 Likes : 0 #1
    I am about to purchase the software but before doing so I want to be sure that it suits my application which is:
    Play a You Tube video,then record between 3 to 6 minutes and then again between 15 to 20 minutes.( as an example )
    Save the recorded parts and download them on my c drive.
    Tks
    Gubert
    Jessica
    Hey buddy,
    Thanks for your interest in our product. First of all, I want to say Video Download Capture can only download the full length video from YouTube, you can not download part of them as per your need. But if you just want to retain a part of them, then you are suggested to trim the videos as your preferred part. Please follow the steps as below:
    1. After downloading, right-click the downloaded items and add into convert panel.
    2. Simply click on “Video Edit” on the program
    3. Choose “Trim”, set the start time and end time
    4. Set it and resume to the convert panel, and then choose your desired output format.
    5. After conversion, it will be saved in your wanted size.
    If possible, a special site that called Tubechop will facilitate you to save part of videos according to your need.
    Gubert
    Thank you for your reply.Unfortunately I still cannot make it work.
    I followed your steps,but after selecting trim and entering the start and end time I get stuck.
    How do I resume to the convert panel ?
    How do I choose the desired output format ?
    And how and where does the clipped video getting saved ?
    Thanks again
    Gubert
reply to: Record parts of a You Tube video
