• Problems converting from 4:3 to 16:9
    LTA
    Views : 1413 Replies : 3 Likes : 0 #1
    I downloaded the launcher, selected a Windows Media audio/video file with a 4:3 aspect ratio, opened edit and put in 1920 and 1080 in the size boxes, selected WMV as desired format, and selected the location for the converted video. The program says the video was converted and there is a icon indicating a file in the folder for the converted video, but there are 0 bytes of data in the file. Anybody with a thought as to what I’m doing wrong?
    Hi, sorry. Would you please send us the file? We want to test it. Please contact us via the email support@apowersoft.com
    Hana
    this happened to me too. mine was a quicktime movie mov file. I entered in 1980 1080 in the size boxes and it also came out with 0 bytes.
    rakanrakano1998
    hi
    Actually, there *is* another solution, albeit a commercial one.  I wrote an add-in to deal with this problem quickly.
    good luck
reply to: Problems converting from 4:3 to 16:9
