• problem in screan recording via mackbook
    Alharbi176
    Views : 246 Replies : 2 Likes : 0 #1
    Hello,
    i just have a problem in screan recording on my macbook device, when i enter on the “setting botton” on the corner in the right side i can’t see the window, it just get darker without any options, please help me as soon as possible.
    Dear user, please go to our official siteand install the latest version of the program, if it still not working, please kindly send support@apowersoft.com a screenshot showing the issue so that our technician can check it for the program. Thank you!
    loriecarter00
    Screen record with sound Mac
    Open Quick Time Player on Mac using Spotlight Search (Command + Space). Do Right Click on Quick Time Play icon showing on the dock, Select “New Screen Recording.” Start to record screen by click on Button on Quick Time player.  Also check
reply to: problem in screan recording via mackbook
