• Phone on Wifi but PC on Wired connection.
    Bjorn Ong
    Views : 1255 Replies : 1 Likes : 0 #1
    When my phone is on wifi and I want to mirror to my pc that’s using ethernet connection. The mirror is laggy. Whereas if I mirror it to a laptop with the same wifi connection, its smooth. Is there a way around this? My ethernet connection is from the same router that is giving out the wifi.
    Yours sincerely,
    Bjorn
    Threads : 37
    Hi,
    Our technicians are checking the issue for you.
    Thank you for your patience.
reply to: Phone on Wifi but PC on Wired connection.
