• Need IT help
    pmack49
    Need IT help
    Views : 458 Replies : 2 Likes : 0 #1
    I just purchased the software. I am having trouble trying to export photos into a folder on my windows 10 CP.  I am able to select the photos I want in the ApowerManager software, but when I select export and select a folder in the powersoft folders, I get a little gear figure saying no task found.
    Need IT help
    Threads : 36
    Hi
    Please contact us at support@apowersoft.com and give a detailed description of your problem.Our technician will check the issue for you. Thank you very much.
reply to: Need IT help
