• Need help with a simple answer
    rs.mediacast365
    Views : 138 Replies : 0 Likes : 0 #1
    Can I somehow use this app to connect with my LEDGER NANO wallet because when I got the ledger I didn’t pay attention to the fact that I should have got the other ledger hard wallet because for iPhones you need the one where u can connect with Bluetooth and the one I have I need to connect using micro usb..if anyone can help me out with this if they have an idea please I’d appreciate it if it’s not possible I’m just going to have to buy the Bluetooth compatible version..thank you all for your help either way this app is great
reply to: Need help with a simple answer
