• Mirror Android screen to pc audio issues
    Proyo313
    Views : 529 Replies : 1 Likes : 0 #1
    So I got everything set up correctly. I’m using Google Home so I can send audio to pc. Problem im having is, When I mirror my screen to my pc I can’t use a headphones on my phone and still mirror the sound to my pc. How do I set it up where I can have headphones hooked into my phone so I can talk to people without background noise and also stream my phone sound to my pc at the same time? Is it possible?
    Threads : 37
    Hi,
    I’m sorry. The headphone cannot be used when mirroring the sound to PC.
    Thank you very much for your support:)
reply to: Mirror Android screen to pc audio issues
