• Machine loses power or reboots during scheduled task
    James
    Views : 1515 Replies : 1 Likes : 0 #1
    Hi i am wondering what happens if the machine i have running the screen capture software suddenly loses power during a scheduled task.
    When the machine recovers and the program opens again does the task recover and begin to start screenshotting again?
    I have set tasks up to screenshot everyday weekly so its a continuous process and it looks like if my machine suddenly lost power on a monday when it booted up again the task would then wait till the week after which would be the next monday before it started screenshotting again.
    Cheers
    james
    Hi James, thanks for your feedback. The issue you mentioned depends on if the machine lost power when the software was running.
    If the machine shut down before the task begins, the software will run as normal. If the machine lost power when the task was running, you need to open the software and reset the tasks again.
reply to: Machine loses power or reboots during scheduled task
