• Is it possible to fix VidtoMP3 not working problem?
    Hans
    Views : 8903 Replies : 5 Likes : 0 #1
    VidtoMP3 fails to convert YouTube videos to MP3 sometimes, so I wonder if it is possible to fix this issue. Also, I’m willing to try other sites like vidtoMP3. Do you have some suggestions?
    DeeDee
    I know that this will automatically add the ID3 tags, but will it let me manually edit them? I like to make my own compilations and that would be a really good feature of the software.
    Chole
    Thanks for your question.
    Apowersoft free online audio recorder is a smart tool, so you can edit ID3 information easily.
    Below is the detailed instruction:
    • In the recorded menu, right click the file you want to edit.
    • A small menu will show up, select “Edit Track Info”.
    • In the small window, enter the Title, Artist, Album, Genre. Or, click “Add” button to add a cover for the song.
    • Later, click “Save” to confirm your edits.
    That’s it. Just add the ID3 tags with ease.
    Lawrence
    Thanks for your information.
    Free video to mp3 is great, but it cannot convert Facebook audio.
    Any other way to get mp3 from Facebook?
    Chole
    #5
    Actually, the Facebook MP3 can be converted by Free Video to MP3 successfully, just take advantage of a little trick.
    1. Open the Facebook video which contains the audio you want.
    2. Copy the webpage URL. Please note, you only need the part which before the “&set=”.
    3. Paste the URL into assigned area on Free Video to MP3, click “Convert” button.
    4. After processing, customize the target format and folder.
    When the download finishes, the output folder will pop up on your desktop immediately. You can listen to Facebook MP3 offline now, give it a shot.
reply to: Is it possible to fix VidtoMP3 not working problem?
