• How can I record Vsee video call
    Jam
    Views : 4660 Replies : 3 Likes : 0 #1
    I need a little help about how to record Vsee video call for our conference meeting. Does this tool have this function? If none, can you suggest some tools? Thanks
    Jessica
    Vsee is an application used for visual communication by letting people have video calls on their computers. This is actually made for medical practitioners and medical people for communication. As the tool becomes known by many, people now use it as a tool for communication for their personal and business usage. Since this is so fast to use as compared with Skype and any other video calling tool, many businesspersons use this for conference meeting. However, this tool does not have the feature of recording a video call. Considering the needs of recording a video call, is a necessity when using Vesee for having conference, chatting with family members and more. With this, it is best to make use of a screen recorder to record Vsee video call.
    Method 1: Apowersoft Free Online Screen Recorder
    This is a free web-based tool which does not require installation and registration. This tool allows you to record long videos as it has no limits of video length as compared with the other free applications. Additionally, this tool can record audio from system, microphone or both. Below are the steps on how to record Vsee video call using this free online screen recorder.
      2.Click on “Start recording” button and then run the tool in your computer (you need to activate Java plug-in to be able to use this tool).
      3.Drop down “Audio Input” and choose the origin of the audio and then drop down “Record” to choose the region of the screen you will record. These tabs are found at the upper part of the tool
      4.Click on “Start” to start the recording and once you’re done, click on “Stop”.
      5.Start the Vsee video call.
      6.To watch the recorded video, click on “Play” button which is located at the lower part of the tool. You may use your media player to watch it.
    In addition to this, this tool has also a pro version. It is known as Apowersoft Screen Recorder Pro. Apart from having all the features of the online one, this tool is more advanced with extreme functions. It has an editing tool which allows you to enhance your recorded videos. You can add arrows, shapes, effects, and even subtitle. Additionally, it lets you merge videos belong to the same topic into an individual one. This tool also possesses a built-in converter, allowing you to choose different formats they want to use.
    Method 2: Jing
    This tool has a paid and free version. It can be used in recording Vsee video call but it needs installation and registration for a Screencast account. To use this tool, after signing up for an account, simply click “Record” button and you will then record the video call. Moreover, this tool has a video recording limit of no more than 5 minutes regardless if it is free or paid. So if you will record a long video, you need to restart the recording in every 5 minutes.
    Method 3: Screenr
    Just like the first one, this is a free online tool which does not require installation. It as well needs a Java plug-in to work. On the other hand, this tool requires you to sign up for an account since the video will be saved on the free space provided by the account. Same as the other free screen recording apps, this tool also has a maximum of 5 minutes with regards to recording videos. To do the recording of Vsee video call, go to Screenr page, run the application and then start the recording.
    Those are the Vsee video call recorders that we recommend to use. It is now easy to record any video call for business, personal and professional purposes.
    Anne
    Actually VSee does allow you to record video calls. It just does not record shared screens.
    Here is our blog post on how to record in VSee http://vsee.com/blog/how-to-record-a-vsee-presentation-and-interactive-session/
    Jessica
    Thank you for sharing this information. But the recorders you mentioned either are too expensive (Camtasia) for people who don’t need professional techs or have time limitation (like Jing and Screenr which we’ve also mentioned). Apowersoft Free Online Screen Recorder is totally free and have no recording time limitation, so it’ll be a better choice to record Vsee.
reply to: How can I record Vsee video call
