• How to prevent Phone Lockscreen while using ApowerMirror?
    c.hintze
    Views : 1641 Replies : 1 Likes : 0 #1
    Dear Madam, Dear Sir,
    I am currently trying to use ApowerMirror with my Samsung S6 Edge via USB on Android 7.0. It work really well, except that my phone will be locked during the usage despite I am active on my PC.
    For example: I am typing a mail in my mail app and suddenly the screen get black und my phone is locked. So for me it seems, that if I am typing on a keyboard my device does not consider this als active usage. However if I am e.g. rolling the screen up and down via the mouse the device will not get locked!
    Is there something I am doing wrong? Or how can I prevent my S6 to get locked despite being used via ApowerMirror?
    Thanks for any help, and
    Best Regards,
    Clemens.
    Threads : 37
    Hi,
    Thank you for using our program. Yes, typing words on the computer won’t be recognized as an activate usage. Please go to “Settings” > “Display” > “Sleep”, and choose a longer time. Thank you!
reply to: How to prevent Phone Lockscreen while using ApowerMirror?
