• How to Activate ApowerRescue Using Activation Code
    Threads : 37
    Views : 4723 Replies : 1 Likes : 0 #1
    Situation 1: If you don’t have an Apowersoft account, then you can follow the steps below to activate the program:
    Step 1. Open ApowerRescue program, click “Log in & sign up”.
    Step 2. Click “Sign up”, enter your valid email address, click “Get” to get a verification code. Enter the received verification code and a password. Then click “Sign up”.
    Step 3. On the pop-up window, input the Activation Code.
    Situation 2: If you already have an Apowersoft account, then you can follow the steps here:
    Step 1. Open ApowerRescue program, click “Log in & Sign up”.
    Step 2. Under “Login” tab, enter your valid email address and the password. Then click “Login”.
    Step 3. On the account interface, move the mouse to your account name, click “Activate” on the drop-down menu and enter the Activation Code.
    Note: If you log in or sign up to Apowersoft using Google+, Facebook or Twitter, or if the version of your Internet Explorer browser is below 11, when you click “Log in & sign up”, it will open your browser. After verifying or logging in your account on the browser, you can close the login page.
    Then you should:
    Step 1. Go back to your program to click the “Account” button on the upper-right corner.
    Step 2. Move the mouse to your account name, click “Activate” on the drop-down menu and enter the Activation Code.
    Threads : 37
    Here’s a complete video for your reference:
    https://youtu.be/3pQdWcn9FN8
reply to: How to Activate ApowerRescue Using Activation Code
