Home › Mirror Android & iOS › Solutions You May Need while Using ApowerMirror
General:
1. How to connect phone to PC via hotspot
2. How to enable “Power Saving Mode”
3. How to manually rotate the mirrored screen
4. Solutions to OBS cannot capture ApowerMirror
5. How to Adjust ApowerMirror Display Quality on Android/iOS
Android:
1. Solutions to Game Keyboard Cannot be Downloaded/Used
2. How to Stream the Android Audio to PC
3. How to Use “Game Keyboard” Feature
4. How to Cast Android Microphone Audio to PC
iOS:
How to Mirror iPhone to iPad
very slow mirraring screen .what is issue? pl solve my problem
Please tell me the version you are using.
não consigo conectar através de usb
excluir e instalei novamente mais o erro persisti
làm cách nào ko mua vip maf dung đc ứng dụng ko.
ó thể kết nối nhưng ko dùng trên máy tính đc nó bắt buộc phải mua nhưng ko đủ điều kiện thì phải làm sao
