• Device does not connect
    sweetwater28679
    Views : 2545 Replies : 6 Likes : 0 #1
    I have an iPhone 5. My pictures loaded somehow, but the screen that is supposed to show when device is connected never appears when I click on My Device. Instead, there is a note to connect devices. I keep changing ports, but that doesn’t help. Anyone know what I’m doing wrong?  Thanks! (I did download iTunes to my computer as well, as instructed.)
    Threads : 36
    Hi,
    Welcome to Apowersoft community. Thank you for your detailed description.
    Could you please tell us your system version? ApowerManager only supports iOS 8.0 and higher.
    Best regards,
    Ada
    vly1968
    Device Huawei is not connecting what might be wrong
    mats.remnert
    The itunes symbol never came up on the screen
    • avatar
      • Apowersoft :
        Hi,
        Do you want to scan QR code to connect your iOS device to your computer? If so, maybe this guide can help you. https://www.apowersoft.com/faq/phone-manager-faq.html If you still have trouble in using the software, then please feel free to contact us at support@apowersoft.com. We will try our best to help you solve the problem. Thank you.
      • 2018-08-16 01:05 Reply
    clarion123
    #5
    I downloaded apowermanager today and have an iphone X. I;m experiencing the same problem. It is trying to connect an apple device but nothing happens. I have the latest version of itunes.
    amt.vns
    #6
    Hey,
    i’m using Lenovo K3 Note android phone, but unfortunately its screen broke down. please help me to cast my screen on my computer.
    Regards
    Ashutosh
    • avatar
      • Ada Reed :
        Hi,
        Can you open your phone and install the app on your phone?
        Thank you.
      • 2018-09-25 01:28 Reply
    TD Gamerz
    #7
    i want to connect through USB but it always failed i dont know why..!! but it never connects i have enabled USB Debugging and all but still i unable please help me..!!
reply to: Device does not connect
