• Audio Problems with 2 mp3 files
    Dylan Blom
    Views : 1486 Replies : 2 Likes : 0 #1
    Hey, so, I am creating a video, and I need to use 2 mp3 files. I put the first one in, and it was great. I tried to put the second one in right after the first one, and it did something weird, and now the second one is playing in the first slot, and where the second sound should be, there is no audio. Please help! Thanks!
    Dylan Blom
    Ok, so I figured something out. It worked when I took out the Fade In/Fade Out on both files. That seemed to be causing the weird desync. It’s a little disappointing I can’t have the fade in/out stuff, but maybe you guys can help fix it? Thanks!
reply to: Audio Problems with 2 mp3 files
