• Apowersoft not default audio device but still playing
    dirtydansie
    Views : 2431 Replies : 2 Likes : 0 #1
    I am not sure why or where the apowersoft_audiodevice came from but it is taking precedence over my laptops default speakers. It doesn’t seem like there is any apowersoft programs for me to uninstall? I am very confused. Thanks for your help.
    Jessica
    Hello,
    Thanks for any feedback and suggestion. You mean that you want to uninstall the Apowersoft Audio-device, if yes, please follow the steps as below.
    1. please tap the sound icon in the Notification Area and choose ‘Playback devices’, you will see Apowersoft_AudioDevice.
    2. Click on “Properties” – “General” and then “Properties” again. And then finally uninstall the audio device.
    Anabel
    great theme
reply to: Apowersoft not default audio device but still playing
