• Apower Mirror frame drop and lag
    Yel Untalan
    Views : 322 Replies : 1 Likes : 0 #1
    Hi there,
    When my phone is on wifi and I want to mirror to my pc that’s using ethernet connection, the mirror is laggy and most of the times pixelated. My interenet is 25mbps.
    Yours sincerely,
    Bjorn
    Crystal
    Hi
    It is probably related with your network, please check the following things:
    Make sure your router is nearby and there is no obstacles between your router and your computer so that the signal is strong.
    Please set your router to 5G network instead of 2.4G, which can improve the transmission
    If you don’t have a stable WiFi, please go to Settings of the program and change the display quality.
    If the above solutions cannot help, could you please follow the screenshot below and send feedback along with log file from the desktop program? Our technician will check it out as soon as possible. Thank you!
reply to: Apower Mirror frame drop and lag
