• Android Phone Huawei Y 6 (5.1) not connecting to Mirror …
    Thomas
    Views : 1466 Replies : 1 Likes : 0 #1
    Everything happened as described. here … (USB-Connection, Debugging etc.)
    But after pushing “Start now” on the Phone i can see the Message “no Authorisation” there for
    1 second, and nothing is shown on the Desktop.
    Thanks ahead. Thomas from Germany.
    Threads : 36
    Hi Thomas,
    Sorry for the late response! Have you tried to restart the program and connect again? If it still cannot connect, please follow the screenshot below and send feedback from the desktop program. Our technician will check it out! Thank you!
    ApowerMirror Feedback
reply to: Android Phone Huawei Y 6 (5.1) not connecting to Mirror …
